Can the mavic pro platinum be used with the smart controller? I find it quite hard to see the phone screen in bright daylight even if turned to the brightest setting. Thanks
You should buy a Crystal Sky monitor. Works with the MP/MPP and the original RCI find it quite hard to see the phone screen in bright daylight even if turned to the brightest setting.
It will also work with the M2P and M2Z... love my 7.5” screen and the touch controls.You should buy a Crystal Sky monitor. Works with the MP/MPP and the original RC
CrystalSky - Product Information - DJI
The DJI CrystalSky monitor has been designed to provide more comfortable viewing under bright light. Discover more about the CrystalSky with specs, FAQs, video tutorials, guides, and user manuals. Download the DJI GO app to capture and share beautiful content. Learn more at DJI.com.www.dji.com
Interesting. Does it fit in the controller bracket?You should buy a Crystal Sky monitor. Works with the MP/MPP and the original RC
You have to use this mounting bracket:Interesting. Does it fit in the controller bracket?
No. I use the mount from PolarPro. I tried several including DJI’s.Interesting. Does it fit in the controller bracket?
The OP has a Mavic Pro Platinum - So, the bracket will fit.No. I use the mount from PolarPro. I tried several including DJI’s.
CrystalSky Remote Mount | Mavic Remotes
PolarPro's DJI CrystalSky Mavic Mount provides a rigid platform for connecting your 7.85 inch or 5.5 inch Crystalsky to your Mavic or Spark Remote Controller.www.polarprofilters.com
Yes.... I fly my M2P with the CS most of the time.I have recently purchases a MPP and use a ipad mini4. It is dedicated to the mavic but is not too bright. If I buy a Crystalsky will it work if I upgrade to a Mavic 2? Also is the 1000 better than ipad or should I go to the 2000?
