Cannot connect to the app when connecting through regular USB.
astroprojector
I am trying to connect my mavic 2 pro using the regular USB connection. I tried Note 8 with USB C cable that came with the drone, I tired S7 with micro usb cable. Nothing seams to work. I able to connect using the short cable that runs on the side of the remote on both phones. The app and drone is one the latest versions. Any ideas what I need to do?
You need to remove the cable on the side of the controller if you haven't already.
Reactions: Thomas B
Device connections through the USB port are now set to charge-only mode by default. To access the device and its content over a USB connection, users must explicitly grant permission for such interactions. If your app supports user interactions with the device over a USB port, take into consideration that the interaction must be explicitly enabled.
  1. Go to 'Apps' > 'Settings' > 'About phone'
  2. Click on 'Build number' approx. 7 times to add 'Developer options' to the Settings menu
  3. Go to 'Apps' > 'Settings' > 'Developer options'
  4. Scroll down to 'Select USB Configuration'
  5. Select the appropriate USB option
If above does not work, the last option is to set the device back to factory defaults:
  1. Go to 'Apps' > 'Settings' > 'Backup & reset'
  2. Tap 'Factory data reset'
  3. Tap 'Reset phone'
  4. Confirm by tapping on 'Erase everything'
refrigasketscanada
