Thanks so much for responding. I've been struggling with this for hours and after a Google search I found the answer. As expected it was operator error. What I thought to be slide switches are not. To move the setting from the left side to the right, you do
not touch the left side dot and
then slide it to the right, you simply touch the right side of the slide bar. I was pretty sure it was something I was doing, since
none of the slides worked. However it seems like bad design to have a slide that doesn't slide. Why not an on or off switch. Anyways, it's working now.
Now I just need to wait for better weather to fly. I read a few threads today about drones crashing in cold weather and from what I can gather it is related to icing of the props. More investigation suggests that the DEW point is critical in assessing whether or not it is OK to fly. Lots of YT videos of guys flying the
MM2 in sub 0C temps but I'm thinking they got lucky or knew more about what constitutes acceptable flying conditions than I do (which is zip). Lots to learn.
Have you got any links to videos you have produced?
