Cant link mavic mini controller to the drone...
Kemiln
Banner elk
So, I just got my mini and charged all batteries, downloaded go fly app and tried to connect it all but the drone will not link up to the controller anyone else have this problem and if so how did you rectify it...Thanks for any help
Hey, so all I've done so far is just power up both the controller and drone, the controller will annoyingly beep continuously and the drone will blink green for awhile then turn red...
I used the search function and found this for you.
Hope it helps.
Someone developed a connection problem like this after a firmware upgrade. He figured out that it would bind if the SD card was removed, but failed again when the SD card was put back in. It worked with the SD card once he formatted it with his PC.
So, try pairing without and with a freshly formatted SD card.
Reactions: Capt KO
Wolf@22
