Can't take off mini 2 after props change
David88
El Salvador
Hi! I changed props on my mini 2, but it does not take off, it moves a little to the right only.
Drone was working fine before this.
It is up to date and calibrated.
Do you think they are not properly installed?
Thank you
Are you sure you have the correct props on the corresponding motors?
Can you spin up the motors without the props fitted?
Reactions: David88
No, that I can see from the blade shapes you have you have an incorrect mixture.
The blades on the right front (RF) and left rear (LR) motors should have a raised section near the hub, the blades on the left front (LF) and right rear (RR) motors should have on NO raised section near the hub. The RF & LR arms have cast in grooves near the motor to correspond with the raised section near the blade hubs, the LF & RR arms have no such grooves.
The blades on the right front and left rear motors should have a raised section near the hub, the blades on the left front and right rear should have on raised section near the hub. The RF & LR arms have cast in grooves near the motor to correspond with the raised sec tion near the blade hubs, the LF & RR arms have no such grooves.
I just took a look at was you said and that was the issue, thank you very much!
Reactions: Atkas
You might have noticed the crucial typo I made, "on" instead of "no", now corrected.
Reactions: David88
Thank you
Just as a matter of interest, why did you change the props?
It is SO easy to screw up which props go on which motors. If I recall, the Mini 1 props used to have different stripes on the ends of the props to make them easier to identify. I just took a look at my Mavic 2 and saw that the props and motors were "color coded" white circle and just black to easily match up the right props on the right motors.
I wish DJI went back to striping or something to identify which are A and B props. If you need one or the other you cannot tell which is which while still in the package. The last time I changed props it seemed like more of a challenge for visual identification unless you're Philius and can remember which prop goes where by how the raised section is near the motors.
yaucano59
