Took this at a castle in the city. Any feedback to improve is welcomed.
Great advice. Will look into slowing down joystick response. That has been my issue right now. It rotates too quickly and it is inconsistent with my finger. Would be nice if it could slow down in software settings.A little fast on the pan movements at about 1:30 in. You could try flying in tripod mode or otherwise slow down your joystick response time in the setup. Another option is to slow it down in editing.
One trick I use in place of a software transition or hard cut is to insert a still frame between 2 clips then pan and zoom through that frame in order to loosely tie the theme together. (aka, Ken Burns effect)
Generally, very good !
Great idea, have to try that............One trick I use in place of a software transition or hard cut is to insert a still frame between 2 clips then pan and zoom through that frame in order to loosely tie the theme together. (aka, Ken Burns effect)........
