Where can I find a cord to charge my Crystalsky monitor? I have a Mavic Air, which does not come with a compatible connector.
search online they make then for mavic chargers also... or get a cheapP4 charger onThanks, but this says for Mavic 2, I have Mavic Air. If they're compatible great, if not, that's a problem.
TAIFU 17.4V 2-Channel Charger and One Remote Control Charger Adapter Power Supply for DJI Phantom 3 Professional Quadcopter 4K UHD Video Camera Drone, DJI Phantom 3 Standard Advanced Quadcopter Drone https://www.amazon.com/dp/B01GNTQJVU/ref=cm_sw_r_cp_api_i_IzHvCbCPEEK7FThanks, but this says for Mavic 2, I have Mavic Air. If they're compatible great, if not, that's a problem.
The Crystalsky monitors works perfectly with the Mavic Air. I use that combination all the time.Crystalsky monitors are not compatible with Mavic Air!
Thanks very much for the thoughtful reply.The Crystalsky monitors works perfectly with the Mavic Air. I use that combination all the time.
But you have to buy a separate charger adapter as the one which comes with the Air does not work with the CS battery charger hub (this is probably the reason DJI talks about it being incompatible). I bought the DJI Osmo 57W Power Adapter as it is quite compact. But you can use any on this list:
CrystalSky Charger Notification
Also please note the DJI mounting bracket which puts the CS below the remote controller does not work with the Air RC (at least not without modification). It is made for original Mavic and Spark. I'm referring to this one:
CrystalSky Mavic Pro/Spark Remote Controller Mounting Bracket - DJI Mobile Online Store (United States)
Instead use a third party mounting solution or this one in combination with a third party base plate:
CrystalSky Remote Controller Mounting Bracket - DJI Mobile Online Store (United States)
I use a PolarPro base plate with the latter one. I.e. the bottom party of this one:
CrystalSky Remote Mount | Mavic Remotes
(I hope the links work. I'm writing this on my phone...)
