Almost had a disaster on my third flight with my MA2. I have a small yard and like to reset the home point around 50 feet away from me as RTH freaks me out when it returns and it straight over head. Anyways I do my preflight checks and software says my battery needs a firmware update. I let it do that which took a couple minutes tops. I fly around and take a flight and did some general flying and then took a few panos. I get out of that mode and change to high FPS as I’ve been shooting at 24fps and wanted to try high FPS. Shortly thereafter the app says the chip is overheating and to rth. Well rth is now set to a place where I don’t necessary want an auto landing to occur so I tried to cancel rth and move it over my yard and it went back into rth again and tried to land over a power line and it clipped the line on the way down and went off balance but recovered and finally landed. My bad on the rth and I probably need to make sure the home position is in a truly land-able place. . Its not that hot here in Chicago. It’s actually one of the first milder days. I simply do not trust this drone to do any sort of long flights now. There were are a few things that were a bit non-standard about this flight. I removed the SD card last night to look at the contents and didn’t put it back in so the quad copter was using the internal storage which I wanted to test. It’s sat idle for the few minutes that it took the firmware to upgrade on the battery and perhaps that could have contributed to the overall temperature within the drone but I did a fair amount of flying so it should have had time to cool off. I know this is a relatively new drone so I’m wondering if anybody else has come across this chip overheating issue. Perhaps I need to see if the rth during the chip overheating failsafe supports the user cancelling or being able to control the craft to some degree. Seems like I was able to cancel and alter its course but it just continued to go back into that mode as it was determined to get home and land. Anyone know the specifics about this failsafe? Should I have been able to cancel more successfully and was I just panicking or Is that condition up there with the likes of having a battery that is at 1% where the drone doesn’t care what the user wants it to do? |
