Standing on ground, how can I shoot a tall building (roughly 150ft high and 4000 sq. yards area)? I want to start circling in front of me and go upwards like spiral. Is there a technique or pattern to follow?
Fly it... Set up a typical poi. Hold a small amount of up elevator. Point the gimbal down as needed.Standing on ground, how can I shoot a tall building (roughly 150ft high and 4000 sq. yards area)? I want to start circling in front of me and go upwards like spiral. Is there a technique or pattern to follow?
Mini 2 with DJI Fly App 1.3What model is your drone and what control app are you using? There are 3rd party apps that have the ability to do a spiral or matrix around a POI (Point Of Interest), either manually or in a programmed mode. Check out DroneLink, Litchi, Maven will work for you.
One thing to be aware of: What happens when your drone circles around the structure? Will it be out of VLOS (Visual Line of Sight) from the transmitter and lose the transmission signal and go into RTH (Return To Home) or will app allow the mission to continue autonomously with a signal loss?
