- Joined
- Feb 15, 2017
- Messages
- 133
- Reactions
- 66
- Age
- 78
Am trying to use DumlDore on a Windows 10 PC to roll back Mavic FW from v01.03.0900 to *.700. Downloaded the zip version of DumlDore from GitHub, and unzipped easily into several files. Launched Assistant2 to check commo with Mavic. Asistant2 hooked up fine and reported the .900 version of FW on the Mavic. Closed Assistant2, launched Dumldore.exe, and got a commo time out message searching for the ftp server (the Mavic). Went back and shutdown firewalls and anti-malware apps and relaunched Dumldore as Administrator. Same result. Assistant2 still finds the Mavic successfully and DumlDore times out.
Deleted Dumldore and repeated the download/unzip process --> same result. Dumldore message says to try a browser pointed to ftp:://192.168.42.2 (that fails too). Message says then to check the RDNIS driver. Best I can tell, the Windows 10 O.S. doesn’t use an RNDIS driver, so I’m wondering if that’s the problem with Dumldore not communicating with the Mavic. But I’m way over my head here, and would appreciate recommendations. Thanks…………..R
