From the way the calibration is done, my imagination is to calibrate the gain of the compass in the X , Y , Z directions so that their readings are the same under the same magnetic field. Is my understanding correct ?
it aligns the drones flight system to the magnetic north .....
Compass calibration is probably the most misunderstood aspect of drone flying.From the way the calibration is done, my imagination is to calibrate the gain of the compass in the X , Y , Z directions so that their readings are the same under the same magnetic field. Is my understanding correct ?
... Your drone has magnetic fields of it's own associated with the motors and electrical currents.
...The only thing that compass calibration does is to identify and measure the magnetic fields which are part of the drone, so they can be ignored.
Excellent point!it can be done for static magnetic fields generated by the magnets in the motors but how can it be achieved for varying magnetic field generated by electric currents ? Bear in mind that the motors are all off during calibration.
You need to be away from magnetic interference (ferrous metals) when you calibrate and when you launch because once it rises up and away from the interference the magnetic values will change. This has led to uncontrolled flights and crashes. Always confirm before flight that the "radar" pointer indicating the direction the AC is pointed and the actual direction agree before launching....If this is really how it works, then it will be OK to do calibration at location with magnetic interference because all it needs is a local magnetic field with constant strength and direction...
If this is really how it works, then it will be OK to do calibration at location with magnetic interference because all it needs is a local magnetic field with constant strength and direction. Whether it is lined up with the earth's magnetic field doesn't matter. I know this is opposite to the understanding of the majority ( including myself in the past ) but it makes sense to me.
When you calibrate the compass you do so in both the horizontal and vertical planes this is sufficient for the Hall Effect sensor to determine magnetic north. The vertical measurement allows the sensor to detect if it is located in the Northern or Southern Hemisphere - don’t forget GPS isn’t needed to determine North.
When you get a good GPS position the navigation system can then apply the correct offset to determine True North.
If there is a stronger than normal magnetic field detected, caused by iron, rebar in concrete, metal fence, car or even overhead powerlines, the compass should warn you with ‘Magnetic Interference’ displayed. Move location away from the source and calibration should complete.
the Inertial Measurement Unit (IMU) uses microscopic capacitors on equally microscopic cantilevers that bend under movement in the X,Y & Z planes. A processor in the IMU reads the change in capacitance as the cantilevers move in each plane and calculates its position in 3-dimensional space at the point the IMU calibrated itself on startup and takes the compass reading to determine which way it is pointing.
At this point the navigation system still doesn’t know where it is other than north or south of the equator. That is enough for the drone to fly by remote control similar to a model aircraft and keep itself and the gimbal level to the horizon.
Adding GPS into the mix gives the drone a position within the global coordinate system used to find any point on earth (except the north or south poles!) and also it’s altitude.
A barometric pressure sensor onboard gives an additional ‘reasonably’ accurate altitude reading, which is used if GPS isn’t available.
So the compass calibration is important as it is the reference for pointing North. The earth’s magnetic field varies throughout the world and even between relatively close locations. Magnetic North is constantly on the move, though very slowly, and if you live, like me in Australia, you have the world’s largest known source of iron ore sat beneath us, which very easily affects compass readings.
Do you know for a fact that DJI are using a MEMS-based compass? They are very susceptible to vibration, which is why we don’t use them in our products. On the tiny scale they are built, a quad copter vibrates a lot.
I would be interested in what DJI use, if they have counted vibration issues.
OK here's my story. I just had my drone replaced by DJI due to Compass error and IMU defect. I tested it in the back yard first with great results. Next I placed it on my concrete front step and lifted off to about 40 meters. It was just hovering there and suddenly took off over my roof and out of sight. I grabbed the sticks and regained control and was amazed just how far it had flown; approx. 300 Meters! I was very concerned and thought that this drone would also have to be returned defective. Then I happen to come across a posting pointing to an app that measures EMF (electromagnetic field), I downloaded the app and immediately went to my step to check for EMF. It was there folks and the meter went RED! It varied in strength as I moved it across my step and I realized I had found my problem. So lets not "knock" this information or analyze it to pieces. My Mini 2 did not pick up this magnetic interference before lifting off however the EMF Detector App did. I will continue using this since it's a great tool to have and could save your drone from a flyaway. Thanks for reading.
Your eyes do the same job without any app.So lets not "knock" this information or analyze it to pieces. My Mini 2 did not pick up this magnetic interference before lifting off however the EMF Detector App did. I will continue using this since it's a great tool to have and could save your drone from a flyaway. Thanks for reading.
