Controller connection error
thomaspiano
Any idea why my controller keeps disconnecting and reconnecting during flight. All firmware is current and battery fully charged. Controller and phone are at 70%.
phone is new Samsung note 8. phone stays connected. states connection error. M2z freezes until remote controller regains connection.
You can try another cable from device to Remote Controller. You can also remove DJIGO4 -restart device and then reinstall. These are just some options to help isolate the issue.
Cable. (Not to steal Starz’ glory of course. ) :)
And if possible, assuming it’s to your liking, folks seem to have better luck with the USB A port on the bottom of the RC and steer clear of the side port. Dollars to donuts the cable is your problem.
KB
Reactions: RTKD
Does this happen when both are fully charged?
From the above, it sounds like it the remote controller disconnecting and not your phone. If so, your phone or cable are not the problem. Unless things have changed with the M2, you should be able to disconnect the phone and still fly. How far away is the M2 when this happens? Do you have the flat sides of the RC antennas facing the M2? Having RTH set to hover would be the cause of your M2 "freezing" until connection is re-established.
Oops, I see that the AC stops. Watch the telemetry on the RC, does it stop updating?
Try manually forcing 2.4 or 5.8 and look at your signal graph via the app.
yes, when both at least 70%
refrigasketscanada
