Corrupted sd card?
Hiwayman
Yorkshire. UK
Guys
Anyone know about corrupted as cards?
I have started getting a single split second white flash on my video..it only does it once and otherwise footage is fine.
I am now trying a different card to see if it happens again...
Views?
Reactions: RadioFlyerMan
Try reformatting the card. If it is a bad sector on the card, reformatting will mark the sector as bad and it won’t be used in the future. Just make sure to offload your data before reformatting, as it will be lost.
Guys
Views?
Don't know if this is the same thing, but I've been doing a lot of time lapse lately. I'll take from 300 to 400 shots at a rate of one every two seconds. Most every set of shots will have one or two "white" unexposed jpg.
I use two different 32 gb cards, formatted by Go 4 prior to starting my shot sequence. It does it on both cards. Both cards are fast U3 cards.
I have not experienced the "white" frame while taking video, just jpg.
Today, with a different card, I have two white flashes , quite close together ( maybe 2 seconds apart) out of about 20 mins of video.
sohil
