- Joined
- Sep 17, 2020
- Messages
- 156
- Reactions
- 103
I did it. I just crashed itSend it back. Likely unseen damage.
more if you’re comfortable by a whole new arm and replace the damaged one.
I think I'll hold out till my DJI insurance runs out and get a new one in a year. I forsee many more crashes, dinks and scratchesSend it back. Likely unseen damage.
Thanks!Why don’t you unscrew it , bend it back into shape, glue up the cracks in the leg and screw it back together
It looks like the tiny screw below the light cover would have pulled out, I’d just carefully epoxy the small hole and when dry screw it back in so it can catch again.Thanks!
That's what I was thinking...thanks for the backup!It looks like the tiny screw below the light cover would have pulled out, I’d just carefully epoxy the small hole and when dry screw it back in so it can catch again.
I just glued it back.You can get a replacement from Aliexpress.com for cheap.
Your extension arms will put a lot of force on this plastic piece.
When you replace it be aware there is an antenna inside the leg.
