Hi,
I'm new to this - only had my drone a month or so - and crashed it into a wall
When i tried to restart it one motor was clearly having an issue. the others powered up then quickly shut down because the fourth did not move. i rotated the prop manually and it was a bit sticky, me manually rotating it seemed to loosen and after this it powered up fine....
The problem is when I flew, it seemed to be unstable and wouldn't hover still. It seems to pull forward when I leave the controls untouched....
Is there a way to reset, recalibrate or inspect what might be wrong? Also, I'm leaving on holiday this Friday, is there a hightened risk it could fall out of the sky if I fly it in this condition?
Any advice much appreciated - thanks
