Crashed my Mavic 2 pro . Seeking advice
Mini 4 bloke
So I crashed my pristine condition M2P.
Well gutted.
The main problem is the camera / gimbal.
So when I turn it on it does the whole dance thing but the camera doesn't centre ..the camera view is working perfectly .
The camera doesn't move up and down on the wheel in the controller.
Any body know if it's terminal being quoted £700 just on my description.
Not sure what to do .
A lot of cash at the moment
Thanks
I don't know. Hopefully someone with Mavic experience will speak up.
When I replaced them for the Phantom, they were one package for easy unplugging and swapping, and the camera did not unplug from the gimbal.
Also, if if they were easily separated, you would have to be pretty confident which component it was you needed (just the gimbal?). I always did the full package and it always worked. (They were cheaper though.)
Chris
Well gutted.
Thanks
I just crashed my M2P for the second time and have the same issue. ESC error 2. The first time it was the motor that was bad. This time I think it’s the ESC board. I may have heated it up too much with the soldering so I’m waiting on a new one to come in. What I found out is that with the M2P parts, you have to order assemblies. I just needed a motor the first time but I had to get the whole arm. Same thing with the gimbal and camera. It’s all one assembly. I’ve looked around and maybe you can get things individually but I’ve only found assemblies. The good thing though is you’ll have spare parts. I have extra antennas, LED lights and arms now. Good luck and be careful unlike I was.
Reactions: JimCanada
Sent off to the repairers today .
I need it to be right .
They know what there doing I am only guessing.
See what happens .
Big bill in the way .
At least it will be guaranteed.
multimrslon
