Can you post the .TXT and .DAT flight log files in the phone for a more informed cause analysis ? The following instruction is extracted from
Mavic Flight Log Retrieval and Analysis Guide :
3. LOG FILE RETRIEVAL
Mobile device DJI TXT logs
The log naming convention, based on the date and time of the start of the flight, is:
DJIFlightRecord_YYYY_MM_DD_[hr-min-sec].txt.
Instructions to find and upload the files directly, with an option to make them public via a link, can be found on both
@msinger's excellent
PhantomHelp website or on
AirData. Those both allow subsequent download of the original txt logs for third-party analysis.
Alternatively, to simply retrieve the txt logs from the mobile device:
With iOS devices running DJI GO 4 you need to access the app files via computer, either using iTunes or with a file system browser such as
iExplorer. The TXT logs are in
Apps » DJI GO 4 » FlightRecords. The same method can be used to access DJI Fly files in
DJI Fly » FlightRecords, but with DJI Fly they are also accessible using the iOS Files app by selecting
Browse » On My iPhone » DJI Fly » FlightRecords.
With Android devices the file system should mount when plugged into a Windows machine, or via various software options on a Mac. With DJI GO 4 the TXT logs are in
DJI » dji.go.v4 » FlightRecord. With DJI Fly they are in
DJI » dji.go.v5 » FlightRecord.
Under iOS the DJI Fly app files are actually accessible directly in the iOS "Files" app, but the DJI GO 4 app doesn't have that option.
If you want help analyzing the data then you can either retrieve the logs and post them here directly, or upload them to
PhantomHelp or
AirData and post the link back here.
AirData also has
automatic log upload (sync) options directly from most of the common control apps.
Mobile device DAT files (DJI GO 4 & DJI Fly)
The DAT file naming convention, based on the date and time of the start of the file, is:
YY-MM-DD-hr-min-sec_FLYXXX.DAT., where
XXX is the flight recorder file index from the
HOME_dataRecorderFileIndex field in the txt log.
These are retrieved by the same method as the TXT logs. Under both iOS and Android they are in a subfolder,
MCDatFlightRecords, in the folder that contains the TXT logs. In some cases, for reasons not fully explained but possibly mobile-device hardware related, and most often under Android, DAT files are not created and that folder is empty. Uninstalling and reinstalling the app sometimes fixes that. One user also found that the process required manual deletion of the app folder (apparently not deleted automatically in the uninstall process) before reinstalling the app.
The DJI Fly app deletes the DAT files if and when it syncs flight records with the DJI servers, and so they are often missing from the
MCDatFlightRecords folder. The iOS version of the DJI GO 4 app does the same since version 4.3.24. The Android version of DJI GO 4 does not delete the DAT files as of 4.3.32.
