Desperate: First Time Mavic Setup
Stophie
Im embarrassed I can't figure this out. My DJI go app will not connect me to the mavic.
I'm not new to DJI drones and I've flown a phantom 4 for since it first came out, but for the life of me I can't setup a brand new mavic.
I've tried upgrading and downgrading the firmware to the both the mavic and controller. tried deleting and reinstalling the DJI ago app. Tried DJI go app 4. Tried a different phone. I'm not sure if I'm missing something really simple or if there's a software or hardware issue.
Can anyone help?
Just watched a video where the guy was trying to connect using the USB port. He couldn't get it to work unless he completely unplugged the cable from the side.
Hopefully you don't have a bum remote...
Here is a video showing how to connect a remote if it isn't already connected.
Best of luck
DB
Thanks! That actually worked! Using my own lightning cable and unplugging that DJI lightning cable totally fixed my problem. I guess that means either the Side lighting cable or port is defective though...
Best of luck
DB
Glad you got something working. Nothing worse then a new bird that you can't fly.
This will help to check your settings when you are ready to go.
It is not defective. About 3 f/w versions ago DJI made a change to prioritize the ports and with this came the fact that you have to physically unplug the side cable for the bottom one to be available upon powering the controller on. If you use a normal micro USB cable in the side port you do not have this issue and the Controller will then prioritize on whichever port you physically connect a device to.
maybe_pilot
