I’ve been in search of a truly pocket sized drone. Something that can actually be carried in the pocket comfortably. My vision is the following,..
Imagine only the body of a Tello. This would serve as a basis of what I envision. In fact, this drone would essentially BE a Tello if it also had retractable arms.
-No GPS, optical position hold is perfectly adequate.
-No controller. The added equipment defeats the purpose of the desired scale of this drone. Phone WiFi touch screen controls are going to be fine for the applications that this drone would be used for.
-720p resolution is fine, As long as the drone can record with an onboard SD card. Although, I believe it wouldn’t be difficult to bump it up to 1080.
-No gimbal. I don’t want this drone to be delicate in the pocket. Software image stabilization is fine.
-Have the casing design reflect the current Mavic lineup so that this drone can be marketed as the Mavic Micro.
Essentially, I want a foldable Tello with onboard recording. That’s all. I have a nice full sized and capable DJI drone in the MA2. This isn’t the same conversation. I don’t need this drone to embody any of those properties. I want an austere pocket drone that can truly be a part of an “everyday carry” situation..
Take a look at the 1601 drone. This is the form factor that I desire. I know that DJI could very easily make something like that, except with some DJI quality. They almost achieved it with Tello. Not much engineering would need to go into this....
