DJI Mavic 2 Enterprise Zoom w/ Custom FLIR 320 Boson Thermal Camera
RCdancer
Approved Vendor
Huntsville, AL
Site
www.dronesar.info
I've been waiting for someone to marry a Bosun 320 to an M2E and then tleedom made me aware of this ....
I asked them for more details:
  1. How does the Bosun mount to the bottom of the existing camera?
  2. Where/how does it connect for power?
  3. Is a separate display required to view thermal?
  4. Is a separate SD card required? If so, where is it?
  5. How much degradation is there on M2E battery performance?
  6. How does the M2E fit in the case with the Bosun? I'm assuming you must disconnect the Bosun. If so, does it also fit in the case?
Reactions: BigAl07
Im not sure you can watch the thermal real time. The Boson has an SD and maybe you have to watch it later.
Also, bear in mind that the Boson is at a fixed angle, so what you see through the gimbal is not necessarily what you will get on the thermal unless the gimbal and Boson are pointing in exactly the same direction at the same time. Same as on an Inspire 2. The flight cam points straight ahead, but the gimbal will point anywhere you want it to.
I talked with them. The Bosun is permanently mounted under the existing camera and they give you a second display to see thermal imagery. I'm gonna wait this year to see if DJI offers a more powerful thermal camera on the M2ED.
refrigasketscanada
