Skyreat
- Joined
- May 28, 2018
- Messages
- 176
- Reactions
- 133
- Age
- 37
Sorry for the inconvenience!I purchased the new filter that says it fits with the gimbal cover on. However, it’s very hard to install the gimbal as well as remove it. How come this is the case? Is the filter not a 1:1 ratio cut as the original Hassleblad filter that comes preinstalled on the drone? I usually have to do a bit of shoving to install the gimbal and a lot of jarring to remove it. It’s a little annoying to say the least. Will this change in a future update? If so, do you guys have a proposed timeframe as to when these newer, smaller cut filters will be available? Thanks, in advance for your time and concern!
NEW VERSION 6-PACK/3-PACK(ND)/1-PACK will in stock in 3 days.( Oct 8- Oct 10, It have been received by amazon now, but need time to check in)
NEW VERSION 3-PACK(PL)/4-PACK will in stock in 1 week.( Oct 12- Oct15)
NEW VERSION 2-PACK is available on amazon now.
Based on the feedback received so far, we received about 5 complaints about improper installation and disassembly. Two of them said it was too loose, and the rest said it was too tight. In fact, When we were designing the second generation, we seriously considered this problem. We think it is very likely that the DJI lens was produced by different foundries, which caused some subtle differences .We tested on different mavic 2 Pro,Different results were obtained. However, in the upgrade version, we modified the four pins of the filter to make the angle smoother and easier to install and disassemble.
Please let me know your order id, i'm not sure the filters set you got is the new version, We'll replace or refund for you if there is any issue.
