DJI Mavic Air 2 $5 Tablet Mount
Love cheap, simple solutions like this!
Anyone know where these can be purchased in the UK?
Looking on the velcro website it doesn't deem that those ones are available:
I really wanted to find a tablet holder that would let me use the shorter cables that came with DJI Mavic Air 2. Plus, I feel like having the tablet closer to the arms makes it less top heavy.
I went to Home Depot, and here's the results.
I made a video showing how it's done.
I'm looking at Velcro website and it says these are 'coming soon' ...wtf :)
@gb160
found these on amazon Wall Hooks, AOMEES 12pcs Self Adhesive Hook: Amazon.co.uk: DIY & Tools
guess they'd do the job
or these
they looks longer
Reactions: gb160
@Shazbot
whats the length of these hooks if you dont mind
thanks
3.5 inches each (almost 9cm)
When they are stuck together 3.75 (9.5cm)
Found these on Amazon UK. They seem similar.
tesa Powerstrips Hooks Large CLASSIC - Removable Self-Adhesive Wall Hook for Glass, Tiles, Wood, Plastic and Other Surfaces - White - Holds Up to 2 kg
Cheers buddy, interestingly the chrome ones are under half the price of the white ones.
@Shazbot is there any reason why the two hooks cant just be glued together permanently with some really strong adhesive? And do away with the velcro altogether?
Actually, that was my original intention. I was looking at the Command Hooks. These were in the same area, and I liked the shape so I grabbed them. I just assumed they were a fake Command brand. It wasn't until I got home that I realized they were Velcro brand.
The glue I had at home was dry, so I decided to try it with included strips.
It seems to hold fine, but a good glue could be a more permanent solution.
The only caution I would say with glue is that if it becomes unglued, depending on how brittle the glue is, it could be instant. If it happens while you're flying the drone, that could be really bad for your tablet. The adhesive strips, if they start to separate, will happen slowly. You'll notice them separating and can fix them before you drop your tablet.
I'll know more after using this for a while.
Thats cool buddy, just non velcro ones opens up a hell of a lot more options when searching...in an ideal world I'd get the ones you have but typically they're not available over here.
I have gorilla glue, the stuff is awesome when allowed to dry for 24 hours with pressure applied...ive used it for sticking bricks back into a wall in my garden that had come loose, the stuffs stronger than cement!
Reactions: crosswired
guys, just got a brainfart...
can we use for example a stripe of aluminium shaped as these hooks are sticking some rubber (rubber sticky tape) in places where it touches tablet and remotes mount?
it would solve '2 parts glued together' issue :)
Reactions: wali
Could do, but it'll look tacky af if I play any part in it...I like the simplicity of two of those hooks stuck back to back.
well, I'll try it anyways waiting for my hooks to arrive :)
G
Good idea. Very clever. Thank you for sharing. Enjoy your flying.
Reactions: Shazbot
In the video I saw that made me think of this, the guy used an old plastic tablet stand like this.
LOL
guess DJI wont make any money trying to sell ipad adapters as there will be 100 home-made solutions already :)
Reactions: wali
What is the size of your ipad? I am curious if this would work on a 10.5 ipad
Edit: Nvm, pretty sure it would work if you just space it out more. Would also need a new cable.
Edit: Nvm, pretty sure it would if you just space it out more. Would also need a new cable.
Yes, you can space it out. I have an old tablet (not compatible) about the same size.
It will hold it, but you're going to have to find a better way to hold the 2 clips together. Maybe try using a small machine screw/nut with a washer.
I could see it separating as I moved it around. See the photo showing the back.
Reactions: Kep498
maniac2000
