Yes all the contacts were clean, and all 5 drones were causing the batteries to melt, or vice versa, all the batteries are showing melting regardless of which drone they're in.Never saw it before. Suspect a fault in the drone since it got all 6 of your batteries. Are all the contacts clean?
My thought would be that one battery with bad contacts (or drone) caused the entire problem. The battery had bad contacts which burned the mating contacts. Then as that battery got exchanged between the other drones burned those as well. Unfortunately by switching batteries between all the drones, eventually all of the batteries and contacts ended up getting burned or arc'ed in the same manner. It may have been originally caused by one of the swollen batteries that has since been discarded, but the damage is done. Unfortunately the only fix I can see is to replace the contact connector on all of the drones, and then replace all of the batteries with new ones as well. I do realize this is a very radical and costly step to take, but I just think the arcing and heating is just going to get worse and worse till one loses power and drops out of the sky. I am not an engineer in any way, but do work with electrical contacts a lot and once burned they normally just keep going down hill. Just my opinion, sorry.Hi there
Has anyone else come across this amount of melting batteries? We have approx 20 batteries servicing 4 drones and they are all now showing burn marks in the lower left 4 contacts. The drone body also shows melting of plastic. Is this common?? Batteries all on average have 70 cycles each.
