I had the same issue with chrome. Said sight has been known to download malicious software.For some reason, my comodo firewall detected the software as a malware.
ch aircraft did you selectYes. Tried it yesterday. Worked.
Then what did you select to make it work with your Mavic mini controller?it works fine ... but you can't select mm in simulator ...
I get new Mini today and it work well with simulator but you need keyboard since Mini RC less 3 buttons compare with AIR.Has anyone tried the DJI Simulator with the Mavic Mini controller?
Keyboard P for C2 and Enter for C1, C for change of View. Mini RC just lack 3 buttons compare with AIR.Anyone knows where is located the C2 button, or what I should press on the MM remote?
LE: used the keyboard instead..
It's confusing for other forum users for you to say that the Mavic Mini controller does NOT work with the DJI flight simulator when the reverse is true - it *DOES* work. I connect my MM controller via USB to a port on my desktop and by selecting Spark as the model I can fly in a number of different scenarios in the free version without issues. Rather say that it doesn't work on *your* computer.Tried to connect the Mavic Mini remote to the dji flight similator and it does NOT work. More to that on the dji web site clearly stated that mavic mini remote is not in the list of supported remotes.
Who managed to get it working, what you did in order to work?
