do i have to remove the nd filters from the camera before i put the safe case on ?
mavicmodx
Bulgaria
is that a problem? should i remove the nd filters after flight? If I leave them on and put the camera guard with the filter on, could that damage the camera?
i use sunnylife nd filter
I would, I already have the feeling that the std cover pushes the gimbal backwards slightly, if the filter touches the cover and increases the push back I doubt that's a good thing. I have concerns about the gimbal damper rubbers taking a permanent stretch.
If you can't tell if there is contact I would err on the side of caution.
Reactions: Dbez1 and mavicmodx
I have the M2P and leave mine on all the time. So far no problems
Reactions: mavicmodx
dvkhamtruocsinh
