.... to create sharp images or video's without post production edits?
Hello,Think you've got a couple concepts mixed into this question. The A2 does D-Cinelike, which is closer to log than linear. As a result, it'll need grading, or at least a LUT to look good. The default video look is fine, while the drone also offers HDR modes for both photo and video that are more heavily processed in-camera to create a finished look.
For images, you can shoot DNG raws, which will also look better with post.
None of these concepts are really tied to sharpness, but instead color and contrast.
The only issue with HDR is it does not allow for shutter speed adjustment. Sometimes causing jittering...Hello,
Good Morning. Thanks for the response. I will give HDR modes a try, in hopes the finished output is nearly as good as messing with post production programs.
Tom
The only issue with HDR is it does not allow for shitter speed adjustment. Sometimes causing jittering...
It all depends what you want in the end.
You can try HDR or just leave it in the normal mode. There's not that much headroom to the files even in Cinelike to even make adjustments, compared to cine style cameras, so I wouldn't worry about it for most outputs.Hello,
Tom
