Does the original Mavic work with the sky grades Mavic 2 pro lut's?
Sure. Works with any video editing software that uses LUTs. But some LUTs are tuned for certain sensors and systems and may not look exactly the same. For example, I use Sky Grade LUTs for my MA2, but they also work for the Mini 2. But because the M2 doesn't have D-Cinelike you will have to make some adjustments when you apply the LUT to a Mini 2 clip.
They might work, but the D-LOG on the original Mavic Pro is quite different from the D-LOG on the Mavic 2 Pro (I've used and color graded both). So while they might work, they definitely won't give the same results.
Reactions: Severian
Yongtaek
