I don't have a Ptouch so opted for amazon and got the wallet ID cards too ;-)I made it myself and put it on the side of the body.
I would never have thought of that, great idea !Back side of either rear arm. It meets visibility requirement while flying and is hidden when folded up.
I put mine on my batteries.I got my FAA ID for my MA2.
I got some stickers from Amazon. Need some ideas on where to place them
They just need to be clearly visible.I put mine on the back of one of the arms. I print them on mailing labels. You can size them to fit and add your ID. if you desire. The smaller the better in my opinion.
I am just the opposite. If I loose it (hopefully that never happens )I want to make sure my info is seen. Just printed out the info and used clear tape to tape it to the top of my MA. Also there is a text file on the sd card with my info.I put mine on the back of one of the arms. I print them on mailing labels. You can size them to fit and add your ID. if you desire. The smaller the better in my opinion.
I’m sure that most of you are aware of the change last year (FAA) that the Registration Sticker must be on the outside of the drone, easily visible. The placement of the sticker inside the battery compartment, or similar is no longer acceptable. Like all of the above ideas, place the sticker outside to be legal. I was wrong in my placement on my MA2 and had to change the sticker location. OOPS. Luckily I did have a old Brother PTouch laying around.
FAA Guidance
FAA Makes Major Drone ID Marking Change
www.faa.gov
Carry on.7. For your own security we suggest you do not to post personal information
Looks like you missed Mavic Mac's image with his phone and FAA numbers on it.Guys we don’t Recommend publishing your personal info in Post so I removed a couple of post.
Carry on.
