FAA Registration
Texbow
If you registered your drone under part 107 and you have received a replacement drone from the manufacturer. Do you need to re-register? I know that hobbyist do not. Registration is good for three years.
Yes you do need to register the new drone. The registration for a drone under Part 107 is tied to the serial number. You need to register the replacement with the FAA. Also a good idea to delete the old one from your FAA registration inventory, just in case the old one does at some point get refurbished and the same serial number is used.
testtest
