fatal.log growing bigger and bigger
mbrogioni
Colle di Val d'Elsa
Hi, after having experienced some "remote connection error" in my Mavic Pro Alpine White I started to investigate.
The first issue was due to the cable between the left port of the controller anche the smartphone, I changed the cable with one from the lower USB port to the smartphone, something seems to go better, but after a little fly I see the error again.
I started to watch inside the folders in the airplane looking for logs, and I have seen the fatal.log is growing and growing .
Looking in the fatal.log I see many row like these:
05-10 00:42:57.377 F/DUSS&53[ sdp_sbuf_get_i: 184]: ( 251): faile to get bufferd
05-10 00:42:57.478 F/DUSS&53[ sdp_sbuf_get_i: 184]: ( 251): faile to get bufferd
05-10 00:42:57.579 F/DUSS&53[ sdp_sbuf_get_i: 184]: ( 251): faile to get bufferd
05-10 00:42:57.680 F/DUSS&53[ sdp_sbuf_get_i: 184]: ( 251): faile to get bufferd
05-10 00:42:57.781 F/DUSS&53[ sdp_sbuf_get_i: 184]: ( 251): faile to get bufferd
05-10 00:42:57.882 F/DUSS&53[ sdp_sbuf_get_i: 184]: ( 251): faile to get bufferd
05-10 00:42:57.983 F/DUSS&53[ sdp_sbuf_get_i: 184]: ( 251): faile to get bufferd
05-10 00:42:58.084 F/DUSS&53[ sdp_sbuf_get_i: 184]: ( 251): faile to get bufferd
the log grow about 1 MB/10 mins .
I tried to:
- reset to factory default
- downgrade the firmware from 01.04.0500 to 01.04.500 with Assistant 2
- reupgrade from from 01.04.0400 to 01.04.0500 with Assistant 2
- calibrating IMU
- calibrating gimbal
- changed intelligent battery
- downgrade the firmware from 01.04.0500 to 01.04.100 with Assistant 2
- reupgrading from from 01.04.0400 to 01.04.0500 with APP
but the fatal.log is growing and growing
I am afraid to have a crash of the airplane while flying and to lose it.
Any suggestion ?
Thank you
Losing remote signal doesn't crash your drone.
It initiates RTH and the drone comes back.
Reactions: Capt KO
Yes, but I'm afraid the crash will happen inside the aircraft, not on the controller.
Maybe after some time the inside storage of the Mavic will be full and the system will crash.
This is my fear.
This is my fear.
I've never heard of that happening
I think you are worrying about nothing.
Reactions: Capt KO
KevinStudent
