Firmware downgrade to access DAT flight logs
Yannie
Hi guys, I'm trying really hard to access flight logs on the drone, would appreciate your insight.
I had the latest firmware, but could only get access to around 12 different flights in DJI Assistant 2 app.
I downgraded to 01.03.0700 successfully. Interestingly, I am still only able to see only a limited number of flight logs in the DJI Assistant 2 app... however, these appear to be DIFFERENT flight logs to the ones that I could access with the latest firmware.
Even the flight numbers on the DAT files are earlier using the 01.03.0700 firmware.
I am wondering if you can only access flight logs with were created using the firmware that you're using to try to retrieve them?
Ie, am I now only able to see the DAT files from the flights which occurred using the 01.03.0700 firmware, when it was the current firmware at the time last year?
I would greatly appreciate your help here, as extracting all my DAT flight logs is proving to be a nightmare.
Thank you
Yannie
AASHIANAPC
