Yes, and I've seen reports that 'upgrading' to 1.04.xxxx will prevent future downgrades if you want to go back. This is being investigated and will hopefully be addressed.New firmware if available!
1.3.1000 & 1.4.0000 can be downgraded but at the moment 1.4.0100 can'tYes, and I've seen reports that 'upgrading' to 1.04.xxxx or 1.03.1000 will prevent future downgrades if you want to go back. This is being investigated and will hopefully be addressed.
Beware.
Thank you for the clarification for accuracy; I've edited my post to remove the incorrect version.1.3.1000 & 1.4.0000 can be downgraded but at the moment 1.4.0100 can't
I have the same issue - image transmission is only 0.34MbpsSo I just upgraded and now video is coming through all messed up and intermittent even with it sitting right on the ground before even starting. I think I'm going to be downgrading it.
Same here. Leaving for FL tomorrow. Wonderful. Hopefully there's a fix.I have the same issue - image transmission is only 0.34Mbps
I did several panos, all of them had the same issue. For every position, it takes three shots, straight, up and down. Every single up was bad - not sure if it's the props or the front of the Mavic. I deleted all of the ups and Lightroom was able to stitch them together. All of the ups look like this!Downloaded and updated with V1.04.01. Besides Pano mode, they have added broadcast identification, its optional if you fill it out and enable it.
Pano worked a treat, impressive.
How was your video feed? Any issues?I did several panos, all of them had the same issue. For every position, it takes three shots, straight, up and down. Every single up was bad - not sure if it's the props or the front of the Mavic. I deleted all of the ups and Lightroom was able to stitch them together. All of the ups look like this!
One thing I noticed... It happened a lot less when i was inside, where it was warmer. Could it be related to temperature? It's 35 out here today.Same here. Leaving for FL tomorrow. Wonderful. Hopefully there's a fix.
Umm, looks like you had a cover installed? Or a lot of headwind?I did several panos, all of them had the same issue. For every position, it takes three shots, straight, up and down. Every single up was bad - not sure if it's the props or the front of the Mavic. I deleted all of the ups and Lightroom was able to stitch them together. All of the ups look like this!
The video feed was great, just like before the upgrade. The only issue I have is the way the pano works.How was your video feed? Any issues?
No cover and the wind is calm.Umm, looks like you had a cover installed? Or a lot of headwind?
Do you have the 30 degree upward gimbal tilt enabled? If so, could that be it?The video feed was great, just like before the upgrade. The only issue I have is the way the pano works.
