You can brick a Mavic while upgrading (or downgrading) the firmware? Let that be a lesson to me.
So what prompted you to want to downgrade?
No, but the preferred method is to format it in aircraft through app. And the firmware must be in the root..not in any folder on external SD... I am unsure if size is a issue for internal SD, but to be safe replace it with the size listed in specs..no bigger or smaller. Not sure where you got that aircraft, but it came factory with a SDCard inside if a Platinum as mentioned above.Now with the SD card the Mavic flashes a little longer when switched on "yellow green red" and then permanently red connects and disconnects all the time.
I bought the SD card new and inserted it inside. Or does it have to be specially formatted?
I might have had that SDCard stuff backwards..I now think as you said, it doesn't come with card but needs one? Anyway your fixed...and your welcome..not like I did much. Fly Safe!! Just cause you can break the rules doesn't mean you need toNow on the second attempt, the Mavic has connected to the laptop
Yes is a platinum. But there was no SD card installed inside.
Flash now with Dumldore or with assistant 2?
