I was thinking more in terms of clearing obstacles above or below rather than the actual landing. I also was relating the draft to pressure and I'm not sure if that's valid.
I'm trying to get my head around the pressure / height relationship. In the OP's example the height (elevation) registered negative so his AC thought it was lower than it actually was. This means, I think, that if his AC had been in RTH mode it would have been flying "higher" than his intended RTH set height. Yes?
In this situation, would the pressure have increased or decreased? Ie. if the pressure rapidly INcreases will the AC be flying higher or lower than the preset RTH height?
I hope I'm making some kind of sense here.
