are you touching the sync symbol in the right hand top of the screen and of course you need internet accessIn my app the log of flights is there but the information above it is not updating. For instance my top altitude is showing -141 ft and the date is 4/6/2018. First how is that possible? Secondly why is that information not updating?
Sorry to disagree. Each time I sync if there has been a change in top speed, distance etc it shows the new figure.The sync just sends the flight logs to DJI so that you can restore it if needed. It doesn't update the top distance, speed. etc..
Surely the TOP records are just that .. TOP RECORD and if there is a change the details are changed.Those are "TOP" records. They will not update at every flight, unless you break THAT record.
I have only flown in Florida and we are basically at sea level. I will fess up to being a bad bay and flying up to 738 feet this week and synced my data after and still the top altitude is showing -141. Every time I have synced I get a window stating my flight recorded have been synced. So let me ask this, how do you restore your flight records? Maybe that would update it.
But you haven't launched from anywhere higher.There is a known bug with the top altitude display. Mine has frozen in the past even when I know I've flown higher.
Your app summary data will update without resetting, synching etc.Yeah I tried that but thanks for the help.
Did you read post #18? What was incorrect?Incorrect Meta4. Just to test that theory I went to a spot that has nothing around and flew up well over 400 feet just to see what the app would do and still the top altitude is showing a negative number. DJI said there was a problem but I have not had a chance to get with them again to look into it further.
