Flying class C airport
I am a FAA license drone pilot but new to the Mavic 2 Pro. I have a little job to do under class C airspace, waiver is in place. My Question is will the Mavic 2 fly there if not can it be over ridden?
Thanks
DJI doesn’t go off of airspace so you’ll need to look on the flysafe map to see if the actual location you are flying is in a GeoZone and what type of GeoZone it is.
If you are going to be flying in the runway path of the airport you may need to get a custom unlock from DJI which takes time so I would figure it out quick. Also doesn’t hurt to take your drone to the location and set it up and see if the props will arm so you know what to expect.
osirus
