Anybody else finding the controller a bit more responsive using one's thumbs rather than the sticks??
To each his own.Um no, not at all and not going to try it either. I personally don't think this is the best way in which to maintain control. If this is better for you then by all means stick with it or better said, stick without it. ?
To each his own.
Interesting perspective - and sounds (in my head) to be true.Longer stick give greater control, you have to move the end of the stick further to get the same movement of the drone, this makes it easier to get a smother control.
No sticks at all undoubtedly make it more responsive because it will move with the tiniest of input making it difficult to be acurate.
What doses that mean? You ask for comments/opinions you shouldn’t be prickly when people take the time to respond.To each his own.
You dropped the analogy I was thinking of offering.It’s true even if I didn’t explain it very well.
Think what it would be like if you had a tiny steering wheel in your car, 1” of movement would be the same as 6” on your normal wheel, would you be driving smoothly or erratically.
I've tried it. Even thought about buying a backup set and cutting them down to around 1/8" numbs.
Yes - of course. You explained it fine. The longer the stick - the more precision.It’s true even if I didn’t explain it very well.
I can see where he is going with this. When you don't need the precision - sport mode - wide open area, short sticks could be advantageous - haven't tried this myself, but am likely to.So did you think you had more control with no sticks ?
I'm going to have to test this first hand. My new smart controller causes me to hold my hands differently and I keep thinking I need to try shorter sticks. Got a lanyard coming which might help out.I do it often enough myself. Really helps when trying to get mild movements for video. With sticks removed, there is still a little bump to still push against. Personally I keep trying to find shorty sticks to replace the long stock ones.
It's not just about control. Comfort of controller and not having to remove them all the time when placing or removing phone.So did you think you had more control with no sticks ?
