That is the older version. New version is Garmin Glo 2Is this it ?
Are you needing to reset the Home Point to the RC location during flight because you are moving with the RC?Just received my Garmin Glo 2 from Amazon on Saturday and it solved my red location icon problem. For those of you that are using a Ipad wifi only or a android tablet without GPS this is a must buy.
All I can say is before I started using the Garmin my Aircraft orientation icon was white but it was not accurate at all. Since using the Garmin it has been spot on accurate.Are you needing to reset the Home Point to the RC location during flight because you are moving with the RC?
If not, the directional location of the original Home Point relative to the aircraft should exclusively be a compass issue and not a GPS issue. All iPads already have a compass, which may occasionally need to be recalibrated, if the direction orientation displays incorrectly.
So you have no need to reset the home point to the RC location during flight? Are you able to successfully do so with the Garmin device?All I can say is before I started using the Garmin my Aircraft orientation icon was white but it was not accurate at all. Since using the Garmin it has been spot on accurate.
I will check and see next time that I fly.So you have no need to reset the home point to the RC location during flight? Are you able to successfully do so with the Garmin device?
The reason I ask is that ability does not currently work correctly on cellular iPads, so I would be surprised if it worked correctly using external BT GPS devices. The workaround for those that need to reset the homepoint during flight while moving is to keep resetting the home point to the current aircraft location while it follows you.I will check and see next time that I fly.
Which wireless GPS APP are you using?Just received my Garmin Glo 2 from Amazon on Saturday and it solved my red location icon problem. For those of you that are using a Ipad wifi only or a android tablet without GPS this is a must buy.
The DJI fly app since that was the issue.Which wireless GPS APP are you using?
