Gimbal Calibration aint what it used to be
Drone on
Hi...
Maybe I'm mistaken.
With my MP1, gimbal calibration moved the gimbal a lot...up, down, left right, kind of all over the place.
With my Zoom, the gimbal moves a little to the left, then sharply to center, then a little to the right, and that's it.
Is that normal?
The app states that the gimbal calibrated successfully, so I assume the process has changed.
What is your observation?
Hi...
Maybe I'm mistaken.
Is that normal?
Never memorized the movements on my M2P.
Are you experiencing a problem?
No real problem.
BTW. I didn't memorize the movement just observed it during re-calibration. I guess I was expecting MUCH more movement being that the MP1 went through a whole gymnastics routine while the MP2 Zoom barely moves.
How frequently do you calibrate your gimbal? I do it about once a month when I observe that the camera has tilted in flight without self correcting in flight. During that flight, I'll adjust the gimbal through the app then re-calibrate later.
If you have the time, please calibrate your gimbal, and let me know, if you see a lot, or little movement of the gimbal.
thanks in advance
No real problem.
thanks in advance
Once unless I notice a problem.
mountain
