Equipment: Mavic Pro Platinum
Problem : Gimbal Failure'
Cause: Unknown. Just started one day in mid flight and never returned to normal. Never crashed.
Description of issue: Gimbal moving sporadic and slamming stops limits
Attempts at Fixing: Have three Gimbals and board assemblies which I swapped components until I had tried each combination
outcome: if the drone is powered up inverted it will remain calm and allow a gimbal calibration. Powering up normal only results in the dreaded "Gimbal Knock"
Question: has anyone found a solution to this issue aside from buying new parts?
