I’ve been using Litchi with good success for a while now but all of a sudden after a couple of incident free flights on the one day the gimbal went thru the normal start up calibration but then finishes on the +30 position while using litchi in the pano mode. I changed modes, shut down litchi, calibrated gimbal etc with no change.
I then switched to DJI go 4 and it worked fine. Returned to Litchi with the same problem.
There wasn’t any warnings apparent so I’m a bit lost. Has anyone had this problem before?
Any help would be appreciated. Cheers
