Hi
Bought a mini from a friend recently. On my second flight the aircraft started to wooble and I loosed control. It fell 10 meters to the ground.
After changing propellers everything seem to work again, until I lifted off. Then I got the codes 40002,40003 (gimle overload, gimble stuck)
Now I have disembled everyhting, cleaned out everything, every movement on the gimle moves smooth by hand and on the selftest at start up.
I have checked the flat cable and the ptz-cable for bad connections or damages. Everything looks good.
Sometimes the errocodes comes directly after selftest.. Sometimes it works perfect when I dont have the propellers running, but at the same time I start to idle the propellers, the errorcodes come back on and the gimble stops working. When it works sometimes I can not tilt camera between 0-22 degress, it just vibrates in the gimble. But if I manage to step by 22 degress and more it works fine again..
What movements does the flat cable handle?
Can it be the cables? Wich one should I start with?
I have uppdated software, recalibrated everything and so on.
Thank you for your help!!
/Johan in Sweden
/Johan in Sweden
