PolarPro has a really nice set that includes an ND8-GR, an ND16-4 and an ND32-8 you can find it HEREHi, I'm looking for some decent quality graduated filters. I mainly use my MP2 for landscape photography, for which it is ideally suited, I just have the normal issue of overexposed skies in some situations. Any recommendations would be most welcome . Thank you.
Here are a few options to consider:I'm looking for some decent quality graduated filters
PGYTECH makes a set that I prefer because they can't rotate. With a GND filter, which attaches the way the M2P filters do, the horizon needs to be horizontal. The rotating round insert is just extra weight that can rotate away from horizontal, and is designed for screw on filters like the M2Z requires, but the M2P filters are attached with spring clips, rather than screw threads. The PGYTECH set was specifically designed to take advantage of the M2P design, rather than just adapted from an inappropriate standard screw on filter that the other manufacturers already had.Thank you both, very helpful.
