Ground Clearance
LordWinston
Southern California
Does the distance to the ground meter on the LCD screen on the controller only work for so many feet? I wanted to fly into hilly areas and knowing the actual distance to the ground would be helpful.
The number in bottom left that's labelled Clearance comes from the VPS which can only sense the ground to 11 metres below the drone.
Beyond that you have to estimate.
Reactions: LordWinston
testtest
