Hand controller question
Janset
West australia
Hi all.
I use a iPad (8 inch) mini on my remote controller.
As such the short wrap around cable located under the pull out antenna is too short. To overcome this problem I purchased 12 inch cable that works well when connected to replace the short wrap around cable as afore mentioned.
As you all would know that to unplug the short cable from it’s socket is a very fiddle thing for fat fingers and there is a serious risk of damaging the said small cable when removing it.
I have tried plugging in the 12 inch cable into the socket located on the bottom of the controller and to the iPad mini, but they will not communicate with each other and the screen only shows the welcome page.
Can anyone enlighten me, is the problem with the cable or is that port/socket only for the charging of the remote controller?
cheers Janset
Reactions: old man mavic
@Janset i do not have the RC you are referring to but i do think that the bottom socket is only for charging and possibly for data transfer from a computer if you go on the DJI web site and download the manual it will tell you what the socket is for
dvkhamtruocsinh
