- Joined
- Dec 13, 2017
- Messages
- 301
- Reactions
- 264
- Age
- 60
Russ posted a you tube video explaining that the micro USB port on the side of the MP Controller can be easily damaged because it looks almost square but the tiny little ‘tang’ or ‘tongue’ inside is slightly offset and repeated insertions of the oe charging cable or an aftermarket cable the wrong way up can eventually lead to damage to the ‘tongue’ and then you can’t charge the controller.
Having viewed Russ’s vlog I placed a small spot of white paint on the connector of the mini usb to indicate which way was ‘up’ and hopefully avoid an expensive repair or replacement of my controller in the future.
