Hello from Alabama.
Status
Not open for further replies.
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Hello from the Crossroads of America SquawkVFR.
I assume you ment DJI mini 2, which is a fine aircraft for the first one.
It won't have to be registered with the FAA unless you add accessories to it that may push it past the 249 g limit.
If you do register, it's only five bucks and the numbers look cool.
You should take the TRUST test and keep a copy with you when you fly.
It's a free no fail test that's easy to take.
Welcome to the Forum. :cool:
Tried posting a picture…it looks like the others I guess.
I hope it doesn't look like this...
I understand that Opossum is the most common Road Kill in Alabama, this is Virginia Road Kill...
  • Wow
Reactions: danwnz and GFields
I have a DJI mini 2. Just got it the other day
You have already ben given the heads up on your legal requirements, so I'll skip that part…
If you are considering acquiring your Part 107 License, here is a link to get you going…
Since you live in Alabama, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mini 2, including the User Manual.
Happy Droning…
Status
marcusjohn3684
