Hello from Cornwall, Prince Edward Island, Canada
Greetings from Birmingham Alabama USA, welcome to the forum!
Welcome to the forum.
Please and do be sure you have read our guidelines.
Don't be shy and ask anything if you can't find it by searching . Thumbswayup
Currently flying DJI Mini 2 and will be upgrading to Air 2 S very shortly.
Welcome from the Hampton Roads area of Virginia, USA. We have a Member's Map in the Upper Right of the Title Bar. Check it out and you might find some new flying friends.
Since you live in Canada, there are specific laws and rules for you to follow, please check to ensure these are current.
Even if you may have flown Drones before, here is some Good Old Fashion Advice…
Below is the link to all of the downloads offered by DJI for the Mini 2 and yur so to be had Air 2S, including the User Manuals.
After you read the Manuals, read them again, you will be surprised what you missed the first time and you will be better prepared for that first "scary moment…"
Happy Droning…
Welcome to Mavic Pilots from Cornwall, PE. I live off the York Point Road and have been flying drones for about 6 years.
Lots of great place to fly in PEI. Cruise ships coming in almost every day, and Rocky Point is a good place to get great shots of them coming into, and leaving, Charlottetown Harbour.
Here is a shot of the Norwegian Pearl taken a few days ago. Happy flying.
Welcome to the forum! :)
MoBeeshy
