Hello from Mechanicsville VA
Hello from the Crossroads of America Gideons Mayhem
reading the manual and studying for the part 107A test for giggles.
So far ,so good. 👍
If you havent done it yet, you should take the TRUST test and keep a copy with you when you fly.
And of course, registration with the FAA.
You've probably already done this, just a bump.
Welcome to the Forum. 😎
Welcome from SEPA, GM. Where abouts is Mechanicsville, VA? I'm curios because VA has its share of mountains. Are you on your first drone there?
Welcome to the forum! :)
Here are some things to help you get started with your drone:
  • Download the DJI manual for your drone here (it doesn't come in the box). The manual is packed with lots of useful tips and will give you a better understanding of your drone's features.
  • Check out this getting started guide for some tips not found in the DJI manual.
  • Your drone batteries will last longer if you use and maintain them like this.
  • Practice flying outdoors in a wide open location that's free of all obstacles. Don't attempt to fly inside your house or in other confined locations.
  • The drone records flight data each time you fly. You can decrypt and view those flight logs with these tools.
  • Check out MavicHelp.com for commonly used accessories you might need.
Just received my Mavic 3 Classic on 01/30/2023, charging batteries and reading the manual and studying for the part 107A test for giggles.
As for giggles... I got my Part 107 so I can fly where you as a Rec pilot can't...
Since you live in Virginia, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
Below is the link to all of the downloads offered by DJI for the Mavic 3, including the User Manual.
Happy Droning…
got the t shirts before I joined the forum.
  • Haha
Reactions: GFields and MA2 317
Happy Droning…
Thank you for all the info. All of my drone activities will be over my mountain property. I'll be flying for fun :) which is why I got the drone, no time or plans to travel or do much else for the next 5 years while we build the log cabin. Anyway thanks for taking the time to write all of that info. My neighbor is a drone pilot for FEMA so I think I have a good mentor. Fly safe and God Bless.
I have a decade on you and I grew up in a log cabin in Upstate New York, Warren County, on the Schroon River, in the Adirondack Mountains. I was 5-years of before we got electric and 7 before we got indoor plumbing… I still miss it… Good Luck with it and remember, even if there are no building codes in your county, you still have State Building Codes that a lot of shady contractors try to ignore since there may be no building zoning inspections in your area. If you suspect you are being shined on, hire an independent inspector, it's cheaper to fix a problem early rather than to find out that your lot doesn't perk evenly and your cabin starts to sink on one side… Or your plumbing freezes up because they did not go deep enough to get below the frost line…
Had a neighbor who paid a bundle to have a huge stone fireplace built. The footing was not large enough nor deep enough and it started to tear the wall apart as the fireplace rose and fell with the ground freezing and thawing and he had to have it jacked up and a whole new foundation built, that cost as much as the original fireplace did…
Just received my Mavic 3 Classic on 01/30/2023, charging batteries and reading the manual and studying for the part 107A test for giggles. I found this forum and figured I would join and say hi and hope to learn. Hope everyone has a good day.
Welcome from south you in Savannah, GA!
Any question you're in search of can definitely be answered here!
You kind of lucked out into a great no-nonsense forum chuck full of info! +1 to You!
testtest
