I'm new to drone flying. I just bought a Min 3 Pro
mavicpilots.com
As a New Drone Pilot, there are a couple of Legal Things you may need to do…
If you have not already done so, you will need to get your TRUST Certificate. You can get that at the Pilot Institute Web Site (FREE…) . If your Drone weighs less than 250-grams (0.55 pounds) and you are flying under The Exception for Recreational Flyers, you are not required to register your Drone.
I registered my
Mini 2 because the TRUST Certificate and FAA Registration established me as a "certified" Unmanned Aerial Vehicle (UAV) Flyer.
Get your FAA TRUST Certificate of Completion to legally fly drones for recreational reasons in the United States.
trust.pilotinstitute.com
faadronezone.faa.gov
If you are considering acquiring your Part 107 License, here is a link to get you going…
Pilot Institute offers courses on drones and airplanes from world-class experts. Pass the Part 107 or Private Pilot exam and take to the skies.
pilotinstitute.com
Since you live in California, there are specific laws and rules for you to follow, please check the link below for all the Rules and Laws that are in effect in your neck of the woods and it also links you to some of the Best Places to Fly in your area… Also, if you travel on vacation, visit friends, and relatives in other parts of the country, check back here so you do not run afoul of the law.
pilotinstitute.com
Below is the link to all of the downloads offered by DJI for the
Mini 3 Pro, including the User Manual.
At DJI Download Center, Learn aboutDJI
Mini 3 Pro
www.dji.com
Happy Droning…
